Bad weather means I get bored and do projects... So lights are going on the 55" Edge so I can fly when there is no wind . I have never done this on something big so we will have to see how it works. Making some little posts to stick them on instead of the sfg is probably in order but they seem plenty bright.
Could you post exactly what components you used to make those lights? I have looked at cree LED's in the past and almost bought some... they are pretty cheap, but I have not ever set up any to run off a lipo. How many cells are you using to drive them? Also, what resistors are you using?
[MENTION=4]3dNater[/MENTION] Here is a night shot with a Crack Pitts and MSXc mini lit up for comparison with TwistedHobbys setup. Plenty bright enough if you keep it close. The left side of the Edge is 3S and the right is 2S. I only have the top set installed right now. No real difference.Thanks for the info! Did you notice much more brightness on 3s vs 2s? I am interested in doing something on my 72" Extra. Perhaps I would need to double them up?
Thanks man![MENTION=4]3dNater[/MENTION] Here is a night shot with a Crack Pitts and MSXc mini lit up for comparison with TwistedHobbys setup. Plenty bright enough if you keep it close. The left side of the Edge is 3S and the right is 2S. I only have the top set installed right now. No real difference. View attachment 34990
