xlr8tion
I have played with the tip on my 76/83 and I have decided to not ever use them again. They add wing area, but reduce the roll authority a lot.
Yeah....they make it more docile for idiots like me! I picked mine up today and it was a "shotgun" purchase in a busy parking lot with the guy in a hurry. Plane was cosmetically perfect and I check for all parts (tips/ sfgs/aileron spacers and wing and sfg bolts)......Check!
Plane looks to not have been flown as the wheels showed zero scuffage on anything. I am halfway home and notice no decals on fuse..NP call him and he says he will send them.
I get home and closely look at the electronics(bear in mind I had my 60lb Dutch Shepherd w.me and trying not to roll the crate on the Fuse in sharp turns).
Get home and upon close inspection notice the arming switch is zip tied under the battery tray wrapped in scotch tape and he is also running a Castle 10A BEC
Here's the plane again...
http://www.rcgroups.com/forums/showthread.php?t=2256260&highlight=64+MXS
I slid the CF tube in and almost needed a hammer to get it in. Then the left wing will not flush up against the fuse from the midpoint to trailing edge...about 3/32" which wont allow the attachment tabs to align in the fuse.
SO....I emailed him and asked how he flew it and whats the deal with the Arming switch. He responded the wing SHOULD fit if I push it hard enough(look at thw center in the ad....see what i mean he does not have either wing pushed all the way in.
So I have to figure a way to determine if its a high point on the fuse where the wing joins where some (stringers or whatever) are NOT flush with the fuse off about 1/64 pr the ultracote is not cut away to expose the total wing insertion area. I will get it on but I do not think he flew it as he said the missing plastic spacers for the sfgs were probably stuck to the end on the wing..LOL...Well you, I thing only use those with SFGS alone and then the bolt goes through the spacer against the SFG-so :bull:
Kid was over his head and I get the feel he bought it LPU for m someone else and never flew it as I asked him what radio he used and he said he was not sure as he was new to the hobby.
So always the drama when I buy a plane and probably wont be needing those plastic washers for a while as I will use the training wheel tips!
Whew...that tired me out. Question......I never run external becs why would he have a Castle 10a BEC wired to the esc plug that the lipo plugs into when the Air Boss 80 has a 5A BEC 4.8 to 8.0 V?
Next weeks surprise the SEBART.
Cheers....
Greg
PS...I read the MXS manual...those ply wing joiner pieces with the hole come installed from the factory in each wing along with the anti rotation pins?
