Hey guys. Happy holidays!
This is my first internal combustion powered build and I had some difficulty specifying the electrical system I was going to use. I ended up buying the Power System 2 from Troy Built. I started to hook everything up last week and found out that the voltage regulator and switch was faulty. I made a short video showing the issue and the manufacturer is going to take care of it.
But now I'm thinking I don't really need that regulator anyway. What I think I'm going to do now is this:
1) Run unregulated 2S Li-Ion battery to receiver.
2) I'm using 4 HS-5565MH servos (control surfaces) and 1 HS-5665MH (throttle) servo which are all rated "High Voltage"
3) I'll use an Ignition Battery Eliminator Filter (IBEF) with opto kill switch to power the ignition system.
Here's a sketch of what the configuration will look like. Do you guys see any problems with this setup?
Thanks,
Marc
Perfect plan.
