Oh, I see what happened! *duh* My glue from doing the joiner got pushed into the slot. Actually, the manual wants you to do the joiner before the horns. But I used epoxy instead of CA (for strength), which, I guess, has more of a tendency to overflow like that. I think I should be able to get it out using a small Dremel bit and a steady hand...
If u dont want to dremel it out u could but the horns/servo on the other side of the fuse, if u havnt installed a push-pull rudder yet
I change my mind. RC Girl is right: Covering up the unused holes is a lot easier than trying to get all the junk out of the slot. And the slots on the other side were all clear.
Thanks for the tip RC Girl!
EDIT: And I had self adhesive Ultracote in the correct color, so the fix took exactly 3 minutes. Life is good!
Got to fly my 72 yesterday!will have a video up soon View attachment 5323
