Hi,
I purchased a BlackHorse SU26m 55cc recently and am having what I consider serious issues. It was on the cheap side for a plane of this size, but I put the cost down to the quality for the hardware (Aluminium U/C and wing tubes instead of carbon fibre...).
However, when I tried to balance it at the recommended place (143 mm back from the LE), I found that I needed 5 pounds of lead to to balance it. After many emails to the dealer and the distributor, they finally said that the COG should be 145mm back from the LE.
I realise that there is a range of COG depending on how you want to fly the plane (I've been flying a Pilot Sbach 55cc for that past 2 years). BUT... I decided to play safe and try to balance it at 150mm.
It now takes 2 pounds of lead... The dealer says this is fine !!! However, I'm suspicious in that if it crashes, they will say it's down to pilot error...
2 pounds of extra weight may be OK for a scale plane, but not for a 3D plane.
Has anybody any experience of this plane or similar COG/weight issues?
Thanks in advance
Ron
Thanks in advance
Ron
