ooh. I missed the 10c part. You've got some cool stuff going on. That 5 # is very light! I haven't weighed mine.... Regardless, it is one heck of a flyer! 16x8 the way to go? Better punch out of a hover than the 15x7? Are you seeing much temp differences between the two props?
A little bit higher. With the 15x7 carbon I was getting barely 1000watts. The 16x8 1300watts. Motor is good for 1800watts so there is head room left and surprisingly everything runs pretty cool (95-100 degrees) in the hot weather! With the 90c packs power is incredible with the 16x8. Also smooth as silk when you want it to be for "dialed in " hovering. With the 3300 packs plane weighs 6lb 2oz. 6lb 4oz with the two series 5200's. I want to try Turnigy's new "Graphine" lipo chemistry packs. They use the new carbon graphite film technology and are supposed to have better punch than the nano-tech's and are a bit lighter and smaller compared to same capacity nano-tech's
