Up for sale is a very nice power package capable of about 1800 watts of power @ 70amps.
Everything listed was bought brand new and is in excellent condition including the batteries.
The package is a 6S set up but capable of 5S to 8S if desired. Here is what you get.....
1) SK3 5055 430kv motor with 3 prong ESC connector plug and optical rpm reflector installed.
2) Aerostar 120 amp opto ESC with 3 prong motor connector plug installed and mounting bracket.
3) ESC programming card V2 with required cables.
4) 2.5 inch (Black painted) True Turn turbo cool spinner and adaptor nut.
5) Spare parts package of X mount and prop shaft / motor shaft adaptors.
6) Two Nano Tech 3300 6S 45C -90C discharge LiPo batteries. ( These batteries have less than 12
cycles on them and are tight hard bricks! Absolutely no swelling and have been kept on a storage
charge of about 55% and monitored every month).
ESC will require a battery connector plug such as the XT60 (female) or similar if you use above batteries.
I was flying this power package in an Extreme Flight 64" MXS and take off weight was a tad under 6 pounds! Flight performance was AWESOME with a 16x8 Falcon carbon electric.
I will be straight up and say I lost the airframe because I forgot to plug up the ailerons but absolutely no damage resulted to the items for sale. They are perfect!
I have the original packaging for the motor and ESC.
With shipping I invested over 350.00. Asking 175.00 for everything. I'm wanting to fund a 30% airframe and this sale will help. So some one HELP me PLEASE
?!!!!!!!!!! That is so awesome!! Good for you Kelly. And way to go
