I can see how a table would serve dual benefits for you. Something to set your cheeseburger on while you're flipping your prop.
Well..........since no one wants to pit bitch anymore
OK! The flight report.......
Sunny blue sky North South runway winds West S.West 5-10mph gusting to 15 occasionally and a chilly 53 degrees 40%RH.
First off.....The DL50 performance rebuild with air filter is AWESOME! Was running a tad rich on LS needle HS needle allowed peak rpm 6800 static. Would rip the Xoar 23x8 Sword (high load prop) in the air.
Plane flies exceptionally well....No rudder trim needed. 2 clicks left aileron and 1 click down elevator. Ended up using 2 clicks down elevator to land because the nose wants to stay up and it wants to stall the left wing tip even when carrying moderate landing speeds. Just like the V1 so I will be visiting the stabs again. CG seemed to be dead neutral in flight. would carry a inverted 45 for quite a distance. Looks like I may move the 8oz weight further forward over the engine. Roll was axial and knife edge was dead on perfect. No coupling. just held the rudder stick and left the ele/ail alone. DL50 had NO problems hauling this 21 pounder.
My landing SUCKED but I had a dead cross wind and possible cg/stab issue. Nothing fancy to see here. But boy do I like the vid because me plane is ONE piece. Oh! did not have the right thrust issue that was present in the V1! Yaaaaaa!
Now see??? Whatidid I tells ya? If you'd use one of my props likes I sajested, ya'll wouldn't have had to get on your knees. The knees are for.... well, you know.OK! The flight report.......
That color scheme is growing on me bro. Looks pretty nice out in the sun. With the right graphics I think it will really pop. Nice job re-building the DL. Sounds smooth and strong.
Plane flies great and that fity sounds awesome. Way to go. Very happy for you.
I really like the scheme much better now too. I agree with @pawnshopmike. I wonder how it would look on a big 330? Lol
. It fractured the CF and bent up the tiller a bit. Rest of plane is perfect though
.That color scheme is growing on me bro. Looks pretty nice out in the sun. With the right graphics I think it will really pop. Nice job re-building the DL. Sounds smooth and strong.
I think I might just have another carbon fiber leaf spring for your tail wheel assembly. I will have a look see and let you know.
I'll talk to @Decal Dennis tomorrow if I don't forget and see if he has any ideas.Tell ya what.....Design one for me and I will let you know the sizes and get em from ya.
