HRRC Flyer
Good evening Fellas,
I have decided to let my old Laser restoration thread die since I hadn't posted anything in it for the last 18 months and also, I will not be doing anything more with that plane (other than trying to sell it). I thought about it quite a bit, but I ultimately decided to start a new thread to keep me from getting confused. . . . .
. The other reason for the new thread is to share with you gentlemen my latest acquisition. This past Saturday, I drove north for about 5-1/2 hours and met someone we all know and admire, our good friend @Bartman. He posted his Laser for sale on another forum and I was intrigued by the pictures he posted. What I didn't expect to see when I saw the plane in person, was without a doubt the best looking Laser I have ever seen and the build quality and covering job was OUTSTANDING! ! ! ! The gentleman who built the plane definitely knew what he was doing. Here are a few pictures of what I came home with.
To say I am overjoyed with this plane is an understatement. The plane came with the matching wheel pants, partial rolls of both the matching burgundy and cream Monocote and a 3 ring binder with a very detailed breakdown of the building of the kit with building instructions, receipts foe everything that was used to build and outfit the plane, pictures of the build process and even notes that were written out to show changes that were made to the construction of the plane. The plane was built in 2003 and it was originally outfitted with a G-62. The plane currently has a DLE-61 that I believe Bart put in it after he bought it. When Bart put the DLE in it, he also removed the two rudder servos from the tail and put a single JR 8711 forward in the fuse with pull/pull cables to the rudder. After making these two changes, Bart said he was able to remove a very large chunk of lead from engine compartment and still maintain a neutral balance on the model. As all of you can tell from the above pictures, this is going to be a very short "Restoration" thread. Bart told me I could charge up the battery and fly it right away and he was absolutely correct. As a matter of fact, I am only changing two things on the plane, both of which are just my preference. The DLE will be removed and a 3W55 will be installed. The other thing is the elevator & aileron servos will be removed and some MKS servos I got from @pawnshopmike will be installed. Both of these things will be done in short order and I'm considering flying the Laser before I fly my Yak.
Stay tuned Fellas, more updates will be forthcoming. . . .
. The other reason for the new thread is to share with you gentlemen my latest acquisition. This past Saturday, I drove north for about 5-1/2 hours and met someone we all know and admire, our good friend @Bartman. He posted his Laser for sale on another forum and I was intrigued by the pictures he posted. What I didn't expect to see when I saw the plane in person, was without a doubt the best looking Laser I have ever seen and the build quality and covering job was OUTSTANDING! ! ! ! The gentleman who built the plane definitely knew what he was doing. Here are a few pictures of what I came home with.To say I am overjoyed with this plane is an understatement. The plane came with the matching wheel pants, partial rolls of both the matching burgundy and cream Monocote and a 3 ring binder with a very detailed breakdown of the building of the kit with building instructions, receipts foe everything that was used to build and outfit the plane, pictures of the build process and even notes that were written out to show changes that were made to the construction of the plane. The plane was built in 2003 and it was originally outfitted with a G-62. The plane currently has a DLE-61 that I believe Bart put in it after he bought it. When Bart put the DLE in it, he also removed the two rudder servos from the tail and put a single JR 8711 forward in the fuse with pull/pull cables to the rudder. After making these two changes, Bart said he was able to remove a very large chunk of lead from engine compartment and still maintain a neutral balance on the model. As all of you can tell from the above pictures, this is going to be a very short "Restoration" thread. Bart told me I could charge up the battery and fly it right away and he was absolutely correct. As a matter of fact, I am only changing two things on the plane, both of which are just my preference. The DLE will be removed and a 3W55 will be installed. The other thing is the elevator & aileron servos will be removed and some MKS servos I got from @pawnshopmike will be installed. Both of these things will be done in short order and I'm considering flying the Laser before I fly my Yak.
