3D 3DHS/Extreme Flight Family - 91" Yak 55 - Black
just a gentle pinch with pliers is the best method. Dont need a lot...start with a little and increase ever so slightly if you need more.
Works like a charm
ryan_m
with the pilot arms and maximum throws without binding i get a good amount of travel, not crazy but looks plenty for this aircraft.
45 degrees seems to be plenty on mine, typically I like a lot of elevator on most of my planes, 55-65 degrees often. But I toned it down on this plane to about 45 and am happy there. I think I have 2" arms on the elevators of mine.
Lojik
I'd say with 1.75in arms I'm bang on 45deg with maxed out throws. End points are at 135% I guess 2in arms would allow me to drop that back to normal end points but I think it will be fine.
ryan_m
actually cranking the endpoints up to 130-140 is ideal for servo resolution and feel, so I wouldn't change a thing! I'll have to look at my radio and see where mine wound up...
Lojik
Sorry for the slow build guys, its been hectic in my house, working 7am till 6pm and its a mentally draining job so I can't find the energy to do any building when I'm home
I did get some work done though, I had to beef up the firewall a touch to pass AU's heavy model criteria so I used 3mm aircraft grade ply and hysol'd a plate onto the front of the firewall with some carbon square tube top and bottom to brace, will get a photo soon, and I did get around to dry fitting the DA70 on the beast this weekend though, doing my usual mistake of drilling in the wrong place... where did i leave that dowel LOL
but once i drilled properly it looks good, I just need to adjust the mount thickness to match the cowl, I'm considering not having a spinner on this bad boy but will decide after its all mounted up, I need about 1/2" more space on the mount to get it to line up
Lojik
I'm sure it will haha, a fair bit more work to do but I'm getting home now at a decent time of the day so should have allot more done over the next few weeks before i go overseas for a "break"
