ChickenBalls
"Cool Guy"
93 ethanol free, simply because it's easy to get local. Only benfit I've seen is my tygon fuel line doesn't harden with ethanol free. Oil 40:1 redline.
They look like rail/beam mounts, looks to me like blind nut installed in back of firewall, and mount screwed threw front.So I was doing some research and making mental notes of things for a 20cc build and I came across these... Miracle "Shock-absorbing Engine mount" I cannot figure out how I would install them and there's not much info online other than "what it does" see below:
"This engine mount is suitable for an airplane which power is 20cc engine and less.
It can absorb the shock during engine running
Whole CNC processing mount with viton washer. Viton can be used for gas.
Can avoid the damage that the engine shock caused to the electronic parts and airplane structure.
It improves the flight stability of the airplane"
Anyone have an idea how they work?
LOL, yup. Problem they missed is that any engine with a beam mount isn't going to shake enough to worry about those!
Sirry Mirico pwodcut designa
Edit, UNLESS!! They may have a valuable product for converting an electric to a 20cc gas, that I did not think of.
@Extraflight456 if you haven't purchased those mounts, try this set. I help a friend who has an Escapade with a dle20 and this mount works fine, cheap to.
http://www.horizonhobby.com/ultra-motor-mount:-61-22-han2033
