Ohio AV8TOR
Just Do It
I have difficulty putting the wings on! it seems that the wing CF tube is a very tight fit. What should I do?
Avoid the urge to sand. My Laser fit pretty good, in fact better than some plane I have had before. Try using talcum power on the tube and slide it in. If you can get it in you are good to go because the vibrations will lap the two together.
I should add that if you feel you have to sand try using super fine 0000 steel wool.
![IMG_0433[1].jpg IMG_0433[1].jpg](https://www.giantscalenews.com/data/attachments/64/64654-97969302dd28edfc72c946d56d3a87ce.jpg)
![IMG_0434[1].jpg IMG_0434[1].jpg](https://www.giantscalenews.com/data/attachments/64/64655-2ffc87ecfa88c3e5c0a35381cdfe14c6.jpg)
![IMG_0435[1].jpg IMG_0435[1].jpg](https://www.giantscalenews.com/data/attachments/64/64656-a217a39f7a553c17a71d1d2cde15cc1d.jpg)
![IMG_0436[1].jpg IMG_0436[1].jpg](https://www.giantscalenews.com/data/attachments/64/64657-a0f1bd123e6fe07917d35bc5defde645.jpg)
![IMG_0437[1].jpg IMG_0437[1].jpg](https://www.giantscalenews.com/data/attachments/64/64658-6c522d2ce884f424f5bc8b4aea72be4c.jpg)
![IMG_0429[1].jpg IMG_0429[1].jpg](https://www.giantscalenews.com/data/attachments/64/64650-cf61040d30900e2887b0a95f08ff6f25.jpg)
![IMG_0430[1].jpg IMG_0430[1].jpg](https://www.giantscalenews.com/data/attachments/64/64651-7ccf31278c68cd1e218b1b988a676ee2.jpg)
![IMG_0431[1].jpg IMG_0431[1].jpg](https://www.giantscalenews.com/data/attachments/64/64652-a5e9148ac9ed56e21e81c2775dcb7051.jpg)
![IMG_0432[1].jpg IMG_0432[1].jpg](https://www.giantscalenews.com/data/attachments/64/64653-de78cc73fed0f49109cae5fe431b8eb5.jpg)
