Curious what kind of hard point blocks you used for the control horns?
I used a solid hard wood in the rudder and just balsa on the ailerons and elevator. I was gong to use had wood but as I was thinking about it the week point is the foam and hard wood or not if its going to pull out the foam is where it will happen. So I hope it holds Lol.
Yap..lots of tape. Looking good.One wing sheeted and the leading and trailing edges glued on. If you build one of these make sure you have a few rolls of masking tape. I think I have used more masking tape on the plane than I have in my entire lifetime.
