Steve_B
Well someone had to be the first to post in the Hobbyking manufacturer forum
opcorn:
Anyway i know there are a few people here who have the Hobbyking 51" Slick 360. Colour scheme aside (lets not go there) it's a decent enough model IMHO but it's somewhat let down by bad wing rock in upright harrier. I did a bit of head scratching and figured the cause was the leading edge shape and/or the area of the vertical stab/rudder. After some modification and flight testing I found that re-shaping the LE didn't make much, if any, difference but adding area to the rudder made a remarkable improvement to stability in harrier. For testing I just stuck lumps of foam on the rudder but I'd drawn up a plan for a new rudder that hopefully strikes a good compromise between adding adequate area and not looking too stupid.
I've attached the plan and parts sheet. the parts are intended to print and stick (using low tack spray adhesive) to balsa sheets. After cutting out the parts the paper can be removed. This works well I've used the same method on many scratch builds back in the day.
View attachment Slick 360 Rudder Plan.pdf
View attachment Slick 360 Rudder Parts.pdf
I've not yet built one myself so if anyone beats me to the build please let me know how it goes together and if you find any problems.
Steve
Steve
