Voltage regulator identification. Help.
see attached photo of a 6 volt regulator I have but do not the amp rating for it. If some body recognizes it and now it's amp rating it would very helpful Tanks.
That is true but if I knew the amp rating the connectors can be changed to suit the amount of amps it is rated for?
Alky6
Looks like TNT landing gear carries those. You may want to check with them. No specs listed.
